13-Feb-2020 16:37
Hi all!
I have question
Cpu4 utilization reaches 80% every hour and after reaches 80% reduces rapidly
why this situation occur? and where can I see documents ??
Solved! Go to Solution.
14-Feb-2020 05:58
Far as I know, there are process on odd number core having normal spikes. As you mentioned even number core, maybe this article help your analisys: https://support.f5.com/csp/article/K63120332
As we can find lot of information about cpu spikes, including issues, better to open a case on F5 to help you to find the root cause.
Best regards,
14-Feb-2020 05:58
Best regards,
16-Feb-2020 16:17
thank you!!
