Technical Forum
Configure Path Routing on F5 LTM
khairi
Hi All
Currently we are using Oracle HTTP Server to load balance traffic to Oracle Service Bus, We would like to replace Oracle HTTP Server with F5 LTM, but I don't know hot to set load balance based on path URL Service on F5. here is existing configuration on Oracle HTTP Server:
<VirtualHost *:7777>
  ServerName soa1.jne.co.id:7001
  ServerAdmin fendi.pnet@gmail.com
  RewriteEngine On
  RewriteOptions inherit
<Location /trackingnew_sb>
  WLSRequest ON
  WebLogicCluster soa1.jne.co.id:7003,soa1.jne.co.id:7103,soa1.jne.co.id:7203
  WLProxySSL ON
  WLProxySSLPassThrough ON
</Location>
<Location /checktariff_sb>
  WLSRequest ON
  WLProxySSL ON
</Location>
</VirtualHost>
4 REPLIES 4
Hello Khairi.
Here you have all the details for the deployment.
https://www.f5.com/pdf/deployment-guides/oracle-rac-database-dg.pdf
Regards,
Dario.
Regards,
Dario.
Hi Dario
Thanks four help, but I can not find how to set load balance based on URL path on https://www.f5.com/pdf/deployment-guides/oracle-rac-database-dg.pdf
Is there another option?
Regards
Labib
Hello Labib.
If the traffic is HTTP, you have thousand of example here in devcentral of how to loadbalance base on URL path.
REF - https://devcentral.f5.com/s/question/0D51T00006i7iZT/redirect-to-different-pool-based-on-url
Using policies is also a good idea.
Regards,
Dario.
Regards,
Dario.
Hi Dario
Thanks for your help, I try first
Regards
Labib
