Citrix Receiver can I force the web interface first
The-messenger_1
I'm running the citrix iapp, latest version 2.4.2. The iapp creates a path for the receiver and web interface, I want to see if anyone knows how I can prevent direct access through the receiver. I want to be sure users go through the web interface first.
I'm running DUO for 2 factor, works great but requires the web browser login.
I know DUO works direct with Citrix and Citrix itself does multi-factor authentication but I want to do all I can to keep the process through DUO for consistency. I have a portal that includes citrix.
2 REPLIES 2
ssharrett14_291
Altostratus
Altostratus
I would just take the reciver branch off of the policy.
The-messenger
Cirrus
Cirrus
Thanks to ssharrett14, I can remove the Receiver leg of the policy to prevent access without the Radius step.
Is it possible to add a Radius Auth step to a Citrix Receiver Access Policy?
