Ciphers for restricting traffic to TLS1.2
Johnde
Cirrus
Cirrus
Hello team,
We want to disable all the lower TLS/SSL versions like SSLv3, TLS1.0 and TLS1.2 under client SSL profiles. I know i can easily do it through options list by enabling no SSLv3 etc. I know we can also achieve it using ciphers. I am looking for that Cipher string.
Does anyone have it? Please share it.
Thank you
1 ACCEPTED SOLUTION
Please try below string.
ALL:!DHE:!ADH:!EXPORT:!SSLv2:!EXPORT40:!EXP:!LOW:!RC4:!SSLv3:!MEDIUM:!3DES:!RSA:!TLSv1:!TLSv1_1
I've used this in my setup and it is working as expected. Hope it helps you too.
Mayur
2 REPLIES 2
Mayur
It worked as per expectations man. Thanks a lot!
