26-Mar-2020 09:12
Hello,
i'm trying to export certificates via a python soap client:
for c in cert_ids:
test = client.factory.create('Common.StringSequence')
test.item = [c]
try :
pem = client.service.certificate_export_to_pem('MANAGEMENT_MODE_DEFAULT', test)
print('found : ', pem)
except:
print('could not find certificate with id : ', test)
However i'm only getting the default f5-bigip certificates (/Common/f5-irule, /Common/default ... ) and not the certificates that i have created.
Can someone please help me fix my python code ?
EDIT:
certs_ids = [ '/Common/default', '/Common/mycert', '/Common/mycert2' ]
Thank you in advance.
