Michel_van_der_
Dec 08, 2003Nimbostratus
Bug with ITCMLocalLB::VirtualServer::create_from_pool_ex?
I'm converting some code from 4.2 to 4.5 (4.5PTF-07 Build18 to be exact). Error creating Virtual Server w.x.y.z:0 for pool ForwardToInside SOAP-ENV:Server ITCMCommon::OperationFailed Exception caught on ITCMLocalLB::VirtualServer::create_from_pool_ex(). primary_error_code : 83 secondary_error_code: 0 error_string : IP address is not valid
I have a forwarding pool defined as 'ForwardToInside'. The code then
tries to use create_from_pool_ex to create a virtual server pointing to
this pool. Under 4.5 this throws an error (this is from perl, numbers
hidden due to security requirements):
However, the virtual server is created!
This all works flawlessly under 4.2 (mostly 4.2PTF-08 Build10, but
we used older PTFs as well).
Thoughts?
