BigIP_DNS VS Capacity Method
Documentation of VS Capacity Method in AskF5 says;
The Virtual Server Capacity load balancing method distributes DNS name resolution requests to pool members (virtual servers) based on a system-generated list of pool members (virtual servers) weighted by capacity. BIG-IP DNS selects the pool member with the greatest capacity most often, but over time, all pool members are returned in responses. When pool members have the same capacity, BIG-IP DNS uses the Round Robin method to select a pool member.
I have a query here. What are all the parameters logically decides the capacity of a pool member/virtual server?
If the project requirement is to distribute DNS based on the_LTM_Active_Pool_MemberCount_per_DC, will it be a good decision to go with VS Capacity Algorithm ? or is there any better algorithm to meet this requirement?
