Vidhya_147819
Apr 11, 2014Nimbostratus
ASM on vCMP
Hi All, Good day! I have a question on vCMP deployment with ASM and LTM. What is the best practice and hence the pros/cons of having ASM/LTM in the same vCMP? We are doing end to end SSL and hence having separate ASM and LTM will mean that we will have to have to encrypt decrypt at 2 different vCMPs? Any pointers/links appreciated. There was a thread earlier, but doesnt address the end to end SSL requirement.
Looking forward for your help! Cheers, Vidhya
