jeffblob1234_20's avatar
jeffblob1234_20
Aug 31, 2015
APM Linux EDGE Client File Checker
hi,
i am using the command line (f5fpc) to connect to the APM.
my policy has a file check policy object.
the file check does not seem to be working, tried using the logging object to print the file check session variables but they are empty.
any ideas?
thanks.
