APM - Citrix kerberos authentication
senthil147_1421
Hi Team
I am trying to configure citrix on F5 APM without replacing storefront functionality - if i use form based authentication it works - after f5 logon / authentication applications are directly getting populated. but i would like to use kerberos authentication instead of form based but its not working and i m getting logon page from storefront.
storefront has already enabled to support kerberos authentication. Does f5 need any specific configuration apart of kerberos SSO?
thanks
1 REPLY 1
Piotrek_72347
yes, there should be addition configuration for kerberos. please read this manual. it should help
https://devcentral.f5.com/articles/apm-cookbook-single-sign-on-sso-using-kerberos
