31-Mar-2021 06:59
Hi everyone,
Below you can find an example of an AS3 Rest API call that creates a simple GSLB configuration on BIG-IP devices.
The main purpose of this article is to share this configuration with others.
Of course, on different sites (github, etc) you can find different bits of data, but I think this example will be useful, because it contains all the necessary information about how to create different GSLB objects at the same time, such as: Data Centers (DCs), Servers, Virtual Servers (VSs), Wide IPs, pools and more over.
"class": "AS3",
"declaration": {
"class": "ADC",
"schemaVersion": "3.21.0",
"id": "GSLB_test",
"Common": {
"class": "Tenant",
"Shared": {
"class": "Application",
"template": "shared",
"DC1": {
"class": "GSLB_Data_Center"
"DC2": {
"device01": {
"class": "GSLB_Server",
"dataCenter": {
"use": "DC1"
"virtualServers": [
"name": "/ocp/Shared/ingress_vs_1_443",
"address": "A.B.C.D",
"port": 443,
"monitors": [
"bigip": "/Common/custom_icmp_2"
"devices": [
"device02": {
"dataCenter": {
"use": "DC2"
"virtualServers": [
"name": "/ocp2/Shared/ingress_vs_2_443",
"port": 443,
"monitors": [
"devices": [
"dns_listener": {
"class": "Service_UDP",
"virtualPort": 53,
"virtualAddresses": [
"A.B.C.D"
"profileUDP": {
"use": "custom_udp"
"profileDNS": {
"use": "custom_dns"
"custom_dns": {
"class": "DNS_Profile",
"remark": "DNS Profile test",
"parentProfile": {
"bigip": "/Common/dns"
"custom_udp": {
"class": "UDP_Profile",
"datagramLoadBalancing": true
"testpage_local": {
"class": "GSLB_Domain",
"domainName": "testpage.local",
"resourceRecordType": "A",
"pools": [
"use": "testpage_pool"
"testpage_pool": {
"class": "GSLB_Pool",
"members": [
"server": {
"use": "/Common/Shared/device01"
"virtualServer": "/ocp/Shared/ingress_vs_1_443"
"server": {
"use": "/Common/Shared/device02"
"virtualServer": "/ocp2/Shared/ingress_vs_2_443"
P.S. The AS3 scheme guide was very helpful:
31-Mar-2021 08:46
Thanks. With what you are generating this ( Python, Ansible etc.) ?
01-Apr-2021 02:26
Hi Nik,
I generated this call in the OpenShift Config Map, I believe you can use it on other orchestration platforms.
