ADD new https connection with different port to a webserver
RPP_337208
Our developers would like to publish a new link through https on a different port but on the same web server. A current virtual address already exists and would like to know how to add another https connection by using the same virtual address.
Just started LTM so please advice.
1 REPLY 1
Maximilian_Mart
You can create another virtual Server with the same IP Address but different Port and use the Same Pool and Profiles of the other virtual Server. Would be also better for Troubleshooting cause it is seperated but does exactly the same. You might want to use Node Based Loadbalancing so the loadbalancing works with both Services.
In case u meant to use a different Port within the same Pool then just add the Node and choose a different Port. I Hope i understood your question.
Greetings, Maximilian Martin
