Technical Forum
active directory with call CN or OU f5 login authentication
herdi
Hi expert
i want to ask how to configure call CN or OU active directory authentication on f5
Group Name Line Order Attribute String
PJKD               1000           memberOF=CN=xxxx ,OU=Group,DC=int,DC=pk,DC=go,DC=id Administrator All Enabled
i dont have clue to configure this
5 REPLIES 5
Lidev
MVP
MVP
Hello herdi,
Have you read this Configuring LDAP remote authentication for Active Directory ?
It's very well documented and includes examples.
Concerning the meanings of LDAP Bindings Strings (CN, OU, DC) , take a look on this website : https://www.rlmueller.net/LDAP_Binding.htm
Regards
yes, i have configure active directory and work well on the remote directory tree when i configured on domain the user not found and when i change to lower level domain the user able to access f5, and on log i found tty unknown that mean the user directory not found
So could i ask what you are trying to achieve?
Is this part of a APM policy? or are you trying to setup log into the f5 using ad/ldap external auth?
My first guess is the Attribute String you have told the f5 to query is lower than the user you are looking for. But i could be wrong! and a little context would be helpful.
this is not apm policy ? Authentication for login to f5
Lidev
MVP
MVP
OK, you can check and debug a user's LDAP access using the ldapsearch command.
if you don't have any more F5 configuration problem, don't hesitate to put the post in solved.
Regards
