28-Jan-2020 20:57
Hi Team,
I needs to create irule (or policy) for the below request, please suggest me how to do:
Calls https://test.com should to go real server with https://192.168.10.5
Calls https://test.com/NAS should to go real server with https://192.168.10.5/NAS
and also on secondary link https://test.com/NAS is present authentication with certificate for app.
31-Jan-2020 21:53
How many Pool members are there behind application "test.com", If only one then all request will be served to node "192.168.10.5" and simple iRule is enough to serve request. No issue with SSL certificate.
if {[HTTP::host] ne ""}{
HTTP::respond 301 Location "https://[getfield [HTTP::host] ":" 1][HTTP::uri]"
HTTP::respond 301 Location "https://[IP::local_addr][HTTP::uri]"
Hope it will work for you.
01-Feb-2020 07:51
Hello Samir,
It is just one pool member.
What do you mean with "if {[HTTP::host] ne ""}" I don't now what "ne" mean?. So this iRule should work?
