sjko_254603's avatar
sjko_254603
Dec 19, 2016
10.2.4 Upgrade to VG 11.5.4 HF2 bug and SIRT support for current version maintenance
i have a question
I am now using VG in version 10.2.4. However, after 10.2.4 EoTS at the end of this year, I am going to upgrade the upgrade to 11.5.4 HF2. Please let me know about the bugs that might be caused by the upgrade of VG you are currently writing. If not, please tell us which version you can keep stable.
I am very worried about upgrade VG.
And 10.2.4 Version soon ends EoTS. If you continue to maintain this version, support for the F5 SIRT (Security Incident Response Team)
  • Have you tried to upload a qkview to iHealth and see if there are any issues with your configuration before upgrading to 11.5.4?
    The biggest change will be your HA setup as V11 changes to device groups, and you'll want to be sure that any iRules you use will work on the new version.
