Technical Articles
F5 SMEs share good practice.
Lori_MacVittie
F5 Employee
F5 Employee
Increasingly WAN optimization solutions are adopting the application acceleration moniker, implying a focus that just does not exist. WAN optimization solutions are designed to improve the performance of the network, not applications, and while the former does beget improvements of the latter, true application acceleration solutions offer greater opportunity for improving efficiency and end-user 0151T000003d8fcQAA.jpgexperience as well as aiding in consolidation efforts that result in a reduction in operating and capital expenditure costs.
WAN Optimization solutions are, as their title implies, focused on the WAN; on the network. It is their task to improve the utilization of bandwidth, arrest the effects of network congestion, and apply quality of service policies to speed delivery of critical application data by respecting application prioritization. WAN Optimization solutions achieve these goals primarily through the use of data de-duplication techniques. These techniques require a pair of devices as the technology is most often based on a replacement algorithm that seeks out common blocks of data and replaces them with a smaller representative tag or indicator that is interpreted by the paired device such that it can reinsert the common block of data before passing it on to the receiver.
The base techniques used by WAN optimization are thus highly effective in scenarios in which large files are transferred back and forth over a connection by one or many people, as large chunks of data are often repeated and the de-duplication process significantly reduces the amount of data traversing the WAN and thus improves performance. Most WAN optimization solutions specifically implement “application” level acceleration for protocols aimed at the transfer of files such as CIFS and SAMBA.
But WAN optimization solutions do very little to aid in the improvement of application performance when the data being exchanged is highly volatile and already transferred in small chunks. Web applications today are highly dynamic and personalized, making it less likely that a WAN optimization solution will find chunks of duplicated data large enough to make the overhead of the replacement process beneficial to application performance. In fact, the process of examining small chunks of data for potential duplicated chunks can introduce additional latency that actual degrades performance, much in the same way compression of small chunks of data can be detrimental to application performance. Too, WAN optimization solutions require deployment in pairs which results in what little benefits these solutions offer for web applications being enjoyed only by end-users in a location served by a “remote” device. Customers, partners, and roaming employees will not see improvements in performance because they are not served by a “remote” device.
Application acceleration solutions, however, are not constrained by such limitations. Application acceleration solutions act at the higher layers of the stack, from TCP to HTTP, and attempt to improve performance through the optimization of protocols and the applications themselves. The optimizations of TCP, for example, reduce the overhead associated with TCP session management on servers and improve the capacity and performance of the actual application which in turn results in improved response times. The understanding of HTTP and both the browser and server allows application acceleration solutions to employ techniques that leverage cached data and industry standard compression to reduce the amount of data transferred without requiring a “remote” device.
Application acceleration solutions are generally asymmetric, with some few also offering a symmetric mode. The former ensures that regardless of the location of the user, partner, or employee that some form of acceleration will provide a better end-user experience while the latter employs more traditional WAN optimization-like functionality to increase the improvements for clients served by a “remote” device. Regardless of the mode, application acceleration solutions improve the efficiency of servers and applications which results in higher capacities and can aid in consolidation efforts (fewer servers are required to serve the same user base with better performance) or simply lengthens the time available before additional investment in servers – and the associated licensing and management costs – must be made.
Both WAN optimization and application acceleration aim to improve application performance, but they are not the same solutions nor do they even focus on the same types of applications. It is important to understand the type of application you want to accelerate before choosing a solution. If you are primarily concerned with office productivity applications and the exchange of large files (including backups, virtual images, etc…) between offices, then certainly WAN optimization solutions will provide greater benefits than application acceleration. If you’re concerned primarily about web application performance then application acceleration solutions will offer the greatest boost in performance and efficiency gains.
But do not confuse WAN optimization with application acceleration. There is a reason WAN optimization-focused providers have recently begun to partner with application acceleration and application delivery providers – because there is a marked difference between the two types of solutions and a single offering that combines them both is not (yet) available.
0151T000003d4HeQAI.png 0151T000003d4HfQAI.gif0151T000003d4HmQAI.png0151T000003d4HvQAI.gif 0151T000003d4HwQAI.png 0151T000003d4IgQAI.png0151T000003d8I1QAI.jpg0151T000003d8MMQAY.png AddThis Feed Button Bookmark and Share
Comments
Don_MacVittie_1
Historic F5 Account
Load Balancers for Developers
Don_MacVittie_1
Historic F5 Account
As NetWork Speeds Increase, Focus Shifts
Version history
Last update:
‎04-Mar-2009 02:29
Updated by:
Contributors
