on 05-Jan-2021 08:12
F5 Beacon empowers you to achieve full visibility across your application landscape, obtain app insights and business intelligence, and make fast, impactful, and better-informed decisions. With the Beacon Insight Engine, you can leverage pre-built insights or create your own custom insights. Beacon also integrates with many types of deployments across hybrid and multi-cloud environments—and provides a rich set of app stats in a simple, easy-to-consume SaaS model.
In addition to app visibility and analytics, Beacon is an open, extensible platform delivering powerful app insights. Pre-built app insights provide intelligence on a specific line of business or practice. Beacon includes easy-to-consume security, operational, and cost insights. You can also create your own customized insights based on unique data sets and requirements to empower decision making and reduce time to execution and resolution.
The Insight feature within F5 Beacon is a centralized portal to get useful information about your application portfolio. Insights are divided into three categories Security, Operations and Cost.
Security Insights:
Operational Insights:
Cost insights:
Beacon has two types of insights, built-in and custom.
Built-in insights are provided by F5 Networks and made available within the service. Such insights include the ‘F5 Assets and Inventory’ insight detailing F5 assets acting as Beacon sources and the ‘F5 App Protection’ insight detailing security findings for BIG-IQ HTTP applications. Built-in insights are updated automatically and cannot be edited or deleted. The built-in insights appear only when relevant data exists (e.g. ‘F5 Assets and Inventory’ appears when F5 sources exist).
Custom insights are based on analyzing any raw data stored in F5 Beacon or outside of it. These insights can be created either via the portal or API.
The following is an example of creating custom insights for BIG-IP and NGNIX.
Step 1: Login to Beacon and navigate to Beacon>Insights and click Create.
Step 2: Select the following options and click Run.
Step 3: View the system status in the graph section.
Step 4: In the Properties section, provide the following and click Save & Close.
Step 5: Navigate to Beacon>Insights and click Create.
Step 6: Select the following options and click Run.
Step 7: View the system status in the graph section.
Step 8: In the Properties section, provide the following and click Save & Close.
This completes Insight creation on Beacon.
This article provided introduction to Insight creation on Beacon.
This article is part of Visibility and Orchestration with F5 Series. Please check out other articles in this series.
