on 29-May-2008 00:01
This installment of iControl 101, I'll focus on the System Service interface where you can have full control of the running state of all the services on the system.
Initialization
This article uses PowerShell and the iControl Cmdlets for PowerShell as the client environment for querying the data. The following setup will be required for the examples contained in this article.
PS > add-pssnapin icontrolsnapin PS > initialize-f5.icontrol -HostName theboss -Username admin -Password admin True PS > $Services = (Get-F5.iControl).SystemServices
Getting a list of services
Like most other interfaces, the get_list() method takes no parameters as input and returns a list of contained objects. In this case, it returns a list of System.ServiceType's that are installed on the system.
PS > $Services.get_list() SERVICE_HTTPD SERVICE_NTPD SERVICE_SSHD SERVICE_SYSLOGD SERVICE_ALERTD SERVICE_ASM SERVICE_BCM56XXD SERVICE_BIG3D SERVICE_BIGD SERVICE_BIGDBD SERVICE_CHMAND SERVICE_COMM_SRV ...
Querying the status of services
There are two methods for querying the status of the services on the system. As illustrated in this example, the get_all_service_statuses() method takes no parameters and returns a list of structures containing the ServiceType in the service field, and the ServiceStatusType in the status field.
PS > $Services.get_all_service_statuses() service status ------- ------ SERVICE_HTTPD SERVICE_STATUS_UP SERVICE_NTPD SERVICE_STATUS_UP SERVICE_SSHD SERVICE_STATUS_UP SERVICE_SYSLOGD SERVICE_STATUS_UP SERVICE_ALERTD SERVICE_STATUS_UP SERVICE_ASM SERVICE_STATUS_UP SERVICE_BCM56XXD SERVICE_STATUS_UP SERVICE_BIG3D SERVICE_STATUS_UP SERVICE_BIGD SERVICE_STATUS_UP SERVICE_BIGDBD SERVICE_STATUS_UP SERVICE_CHMAND SERVICE_STATUS_UP SERVICE_COMM_SRV SERVICE_STATUS_DOWN ...
If you are concerned with a single service, or even a small subset of services, you can use the get_service_status() method that takes as input an array of ServiceTypes and returns, like the get_all_service_statuses() method, an array of structures containing the ServiceType and ServiceStatusType values for each requested service.
PS > $Services.get_service_status( ("SERVICE_HTTPD", "SERVICE_ASM") ) service status ------- ------ SERVICE_HTTPD SERVICE_STATUS_UP SERVICE_ASM SERVICE_STATUS_UP
Controlling services
Querying the status of a service is nice, but the real fun is stopping or restarting a service. The set_service() method takes as input an array of ServiceType's and a single ServiceStatusType to assign to all of those services. The below example will stop the eventd service and then query the eventd service's status to verify that the action worked. I then call set_service() again, this time enabling the service and querying the get_service_status() method to verify that it's back up.
PS C:\> $Services.set_service( (,"SERVICE_EVENTD"), "SERVICE_ACTION_STOP") PS > $Services.get_service_status( (,"SERVICE_EVENTD") ) service status ------- ------ SERVICE_EVENTD SERVICE_STATUS_DOWN PS > $Services.set_service( (,"SERVICE_EVENTD"), "SERVICE_ACTION_START") PS > $Services.get_service_status( (,"SERVICE_EVENTD") ) service status ------- ------ SERVICE_EVENTD SERVICE_STATUS_UP
There may be a situation where you want to restart all running services. This can be accomplished with the set_all_services method. It takes as input the ServiceStatusType you would like to set and applies it to all of the services. This is equivalent to calling the set_service() method passing in the list of ServiceTypes returned from the get_list() method.
PS > $Services.set_all_services("SERVICE_ACTION_RESTART")
Start, Stop, and Restart are not the only controls you can use. There are also Reinit, Add to Boot List, Remove from Boot List, Add to Default List, and Remove from Default List. The values are defined in the following table.
SERVICE_ACTION_START 0 Start a service. SERVICE_ACTION_STOP 1 Stop a service. SERVICE_ACTION_REINIT 2 Reinitialize a service. SERVICE_ACTION_RESTART 3 Restart a service by stopping and starting the service SERVICE_ACTION_ADD_TO_BOOT_LIST 4 Add a service to the boot/reboot list. If on this list, the service will be started on bootup and stopped on reboot. SERVICE_ACTION_REMOVE_FROM_BOOT_LIST 5 Remove a service from the boot/reboot list. If on this list, the service will be started on bootup and stopped on reboot. SERVICE_ACTION_ADD_TO_DEFAULT_LIST 6 Add a service to the default action list. SERVICE_ACTION_REMOVE_FROM_DEFAULT_LIST 7 Remove a service from the default action list.
So, if you never want to see the TMM running again, then you can call set_service_status on SERVICE_TMM with SERVICE_ACTION_STOP and SERVICE_ACTION_REMOVE_FROM_BOOT_LIST and you'll be all set. Warning, doing so will disable almost all functionality on the BIG-IP so it's not recommended.
Controlling Remote Access
There are a couple of methods controlling the ssh service. Specifically you can query and set the enabled/disabled state of specific client addresses. The get_ssh_access_v2() method will return an array of states and a address list for each entry in the restriction list.
PS > $Services.get_ssh_access_v2() state addresses ----- --------- STATE_ENABLED {ALL}
If you want to add a restriction for a specific client address, you can do so with the set_ssh_access_v2() method that takes as input a SSHAccess_v2 structure containing the EnabledState and array of addresses for that state. This example will disable ssh access from client address 10.10.10.10 and verifies the call succeeded. It then will overwrite the previous entry with enabled access for all client addresses. The special value of "ALL" can be used for all addresses.
PS > $SSHAccess = New-Object -TypeName iControl.SystemServicesSSHAccess_v2 PS > $SSHAccess.state = "STATE_DISABLED" PS > $SSHAccess.addresses = (, "10.10.10.10") PS > $Services.set_ssh_access_v2($SSHAccess) PS > $Services.get_ssh_access_v2() state addresses ----- --------- STATE_DISABLED {10.10.10.10} PS > $SSHAccess.state = "STATE_ENABLED" PS > $SSHAccess.addresses = (, "ALL") PS > $Services.set_ssh_access_v2($SSHAccess) PS > $Services.get_ssh_access_v2() state addresses ----- --------- STATE_ENABLED {ALL}
Rebooting the System
In the rare case that you need to reboot your system, the System.Services interface can help. The reboot_system() method takes as input a number of seconds until reboot. This method call is equivalent to the /usr/bin/delayedReboot command line program on the BIG-IP.
PS C:\> $Services.reboot_system(5)
Conclusion
With the System.Services interface, you have full control of what services are running on the system, and control to enable or disable them at your whim. Use this power wisely as it could have adverse effects if you disable a service that you are relying on running.
sub get_ssh_access_v2()
$soapResponse = $System->get_ssh_access();
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
else
$SSHAccess = $soapResponse->result;
my @SSHAccess = $soapResponse->result;
foreach my $SSHAccess (@SSHAccess)
$state = $SSHAccess->{"state"};
@addresses = $SSHAccess->{"addresses"};
print "$state";
print Dumper @addresses;
$i = 0;
foreach $addresses (@addresses)
print Dumper $addresses[$i];
print "$addresses[$i] \n";
$i++;
return(0);
PS > $SSHAccess = New-Object -TypeName iControl.SystemServicesSSHAccess_v2PS > $SSHAccess.state = "STATE_DISABLED"PS > $SSHAccess.addresses = (, "10.10.10.10")PS > $Services.set_ssh_access_v2($SSHAccess)PS > $Services.get_ssh_access_v2() state addresses ----- --------- STATE_DISABLED {10.10.10.10}PS > $SSHAccess.state = "STATE_ENABLED"PS > $SSHAccess.addresses = (, "ALL")PS > $Services.set_ssh_access_v2($SSHAccess)PS > $Services.get_ssh_access_v2() state addresses ----- --------- STATE_ENABLED {ALL}
http://tstdmzdevcentral.olympus.f5net.com/wiki/default.aspx/iControl/PerlSshAccess.html
-Joe
This routine returns a failure: Cannot convert a struct to a string.
can you assist please?
Thank you very much for the previous example. Very helpful!
Subroutine: set_service
Purpose: Sets the service status for a service
sub set_service()
my ($servicetype, $serviceaction) = (@_);
print "servicetype $servicetype, serviceaction $serviceaction\n";
if (!($servicetype)) { &usage(); }
if (!($serviceaction)) { &usage(); }
$soapResponse = $System->set_service
SOAP::Data->name(services => [$servicetype]),
SOAP::Data->name(service_action => [$serviceaction])
else
&get_service_status($servicetype);
return(0);
System.Services.set_service(
in ServiceType [] services,
in ServiceAction service_action
You are coercing both parameters into arrays by placing brackets around them. Remove the brackets around the second parameter and you should be good.
SOAP::Data->name(service_action => $serviceaction)
Thank you very much for your help.
