Matt_Mabis
F5 Employee
F5 Employee
I decided to start a series on my work with Beacon with Ansible. Utilizing the existing documentation and some good Ansible elbow grease I was able to knock out some of the prerequisites and the basics of communication with Beacon all within Ansible instead of using Postman for the prerequisites and Ansible for the communications parts.
My hope for this series is to get to a point where you can see how to use Ansible to gather BIG-IP and BIG-IQ Data and inject it into Beacon through automation.
What is F5 Beacon?
F5 Beacon, a SaaS offering, provides visibility and actionable insights into the health and performance of applications. Driven by an application-centric approach, F5 Beacon empowers leaders and app owners with the right set of visibility, monitoring, and analytics across their entire application portfolio.
Beacon offers:
  • End-to-end app visibility:
  • Account for all applications irrespective of where they are deployed
  • Review the health status of applications
  • Gain operations, security, and cost insights
  • Single pane of glass, where telemetry data from different sources can be fused together to provide actionable insights.
  • Ingest telemetry data from different sources, leveraging built-in integrations:
  • F5 portfolio of products and services
  • Telegraf: A plugin-driven server agent for collecting and reporting metrics from 170+ sources
  • Other sources: Datadog - Synthetics service and Up-time Robot leveraging our open declarative APIs and Web-hooks (see Ingest API)
What is Ansible?
Ansible is a universal language, unraveling the mystery of how work gets done. Turn tough tasks into repeatable playbooks. Roll out enterprise-wide protocols with the push of a button.
  • Automate - Deploy apps, Manage Systems, Crush Complexity.
  • Accelerate - Solve problems once and share the results with everyone.
  • Collaborate - Break down silos, create a culture of automation
  • Integrate - Automate the technologies you already use
The Basics and Prerequisites
Installing Beacon Collection in Ansible - ( https://galaxy.ansible.com/f5networks/f5_beacon )
Currently the Ansible collection for Beacon can be donwloaded and installed with the ansible-galaxy command directly or a wget to download the tar.gz file and manually installed with the ansible-galaxy command. Because the collection is currently is not a version 1.0+ you must call out the specific version of the code during the ansible-galaxy command for it to work correctly
My Machine
I used a VM with CentOS Linux release 7.7.1908 (Core) installed and Ansible version was latest build available at the time using Python 3
ansible 2.9.9
 config file = /root/.ansible.cfg
 configured module search path = ['/root/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
 ansible python module location = /usr/local/lib/python3.6/site-packages/ansible
 executable location = /usr/local/bin/ansible
 python version = 3.6.8 (default, Apr 2 2020, 13:34:55) [GCC 4.8.5 20150623 (Red Hat 4.8.5-39)]
Prerequisites/Notes:
Download/Install the collection from Ansible Galaxy command
ansible-galaxy collection install f5networks.f5_beacon:==0.5.2-beta
Accessing Beacon and your Primary_Account_ID
Accessing Beacon
Make sure prior to this point you have access to Beacon via a user account, this is step must be confirmed prior to moving below because without a user account you will not be able to get access to your Primary_Account_ID and authenticate to the APIs.
If you have access to F5 Beacon and are successfully authentication you should be able to access the Map and List Views within F5 Beacon.
Accessing Your Primary_Account_ID via Ansible Playbooks
The primary_account_id is an essential part of accessing your Beacon environment and will be utilized for further code down the road for F5_Beacon API calls.
My vars file (located away from my playbook ../vars/f5_beacon.yml (Only change the Username/Password, everything else is correct including the host)
ansible_host: "api.cloudservices.f5.com"
ansible_user: "My-Username_for_F5-Beacon"
ansible_httpapi_password: "My-Password_for_F5-Beacon"
ansible_network_os: f5networks.f5_beacon.f5
ansible_httpapi_use_ssl: yes
cur_state: present
My Inventory File (located away from my playbook ../inventory/f5_beacon.yml
[beacon]
beacon_node ansible_host=portal.cloudservices.f5.com
My modified Playbook (f5-beacon-primary_account_id.yaml) for getting the Primary_Account_ID (Debugs are for ensuring that tokens and the ID is properly stored and displayed)
- name: Get Beacon Primary Account ID
  hosts: beacon
  gather_facts: false
  connection: httpapi
  collections:
    - f5networks.f5_beacon
  vars_files:
    - ../vars/f5_beacon.yml
  tasks:
    - name: Login to Beacon to get Access Token
      uri:
        url: https://api.cloudservices.f5.com/v1/svc-auth/login
        method: POST
        body_format: json
        body: '{ "username": "{{ansible_user}}", "password": "{{ansible_httpapi_password}}"}'
        status_code: 200
      register: login
    - debug:
        var: login.json.access_token
      uri:
        url: https://api.cloudservices.f5.com/v1/svc-account/user
        method: get
        headers:
          Authorization: "Bearer {{login.json.access_token}}"
        status_code: 200
      register: user_data
    - debug:
        var: user_data.json.primary_account_id
Running the playbook (as i use separated inventory files in lower directories so they are not captured in GitHub synchronizations i call it during the play)
ansible-playbook -i ../inventory/f5_beacon.yml f5-beacon-primary_account_id.yaml
Output (with essential data removed or changed for security) - When the code executes properly you will get a long Access Token and the Primary Account_ID will be shown. These are the first essential parts to getting access to beacon.
PLAY [Get Beacon Primary Account ID] ***********************************************************************************************************************
TASK [Login to Beacon to get Access Token] ****************************************************************************************************
ok: [beacon_node]
TASK [debug] **********************************************************************************************************************************
ok: [beacon_node] => {
    "login.json.access_token": "eyJraWQi..."
ok: [beacon_node]
    "user_data.json.primary_account_id": "a-..."
PLAY RECAP ************************************************************************************************************************************
beacon_node                : ok=4    changed=0    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
Verify Beacon Access.
This time i will be cloning the previous play and adding another task to confirm connectivity to Beacon.
In my Web Portal we have already imported some VIPs (VMware Horizon) into Beacon that will be translated and shown in the access command
Code with Add-in
Filename - f5-beacon-data.yaml
- name: Get Beacon Data
  hosts: beacon
  gather_facts: false
  connection: httpapi
  collections:
  vars_files:
  tasks:
      uri:
        method: POST
        body_format: json
        status_code: 200
      register: login
    - debug:
      uri:
        method: get
        headers:
        status_code: 200
      register: user_data
    - debug:
# Gather Information about Beacon
    - name: Collect Beacon Information
      beacon_info:
        preferred_account_id: "{{ user_data.json.primary_account_id }}"
        gather_subset:
          - tokens
          - sources
      register: beacon_info
    - debug:
        var: beacon_info
ansible-playbook -i ../inventory/f5_beacon.yml f5-beacon-data.yaml
Output (with essential data removed or changed for security) - When the code executes properly you will get a long Access Token and the Primary Account_ID and Beacon Data will be shown.
PLAY [Get Beacon Data] ************************************************************************************************************************
ok: [beacon_node]
ok: [beacon_node]
TASK [Collect Beacon Information] *************************************************************************************************************
ok: [beacon_node]
    "beacon_info": {
        "ansible_facts": {
            "ansible_net_queried": true,
            "ansible_net_sources": [
                    "last_feed_time": "2020-07-06T06:59:09Z",
                    "name": "BIG-IQ-d413...",
                    "token_name": "Horizon_data_Ingest",
                    "type": "bigiq-system"
                    "last_feed_time": "2020-07-13T18:49:51Z",
                    "name": "Horizon-BIP.bd.f5.com",
                    "type": "bigip-system"
            "ansible_net_tokens": [
                    "access_token": "a-aalb...",
                    "create_time": "2020-07-16T03:02:54.809199Z",
                    "description": "Ansible Token",
                    "name": "ExampleToken",
                    "source_count": 0
                    "create_time": "2020-05-20T17:13:33.203313Z",
                    "description": "",
                    "name": "Horizon_data_Ingest",
                    "source_count": 2
        "changed": false,
        "failed": false,
        "queried": true,
        "sources": [
        "tokens": [
                "source_count": 0
                "description": "",
                "source_count": 2
I know this information will be useful to those looking for automation integrations with F5 Beacon using Ansible. Stay Tuned for the next part in the series.
Version history
Last update:
‎31-Aug-2020 16:26
Updated by:
Contributors
