Problem this snippet solves:
This codeshare has been deprecated. Moved to https://devcentral.f5.com/s/articles/WebUI-Tweaks
How to use this snippet:
Code :
89433
Tested this on version:
13.0
Comments
Version 2.0.3
  • Making data group list parsing in iRules ~10x faster.
  • Now matching data group lists across all partitions instead of just common and current.
  • Only loading data group list content when the user hovers the mouse over a data group list name.
/Patrik
Version 2.0.4
Caching data group list contents when doing the popup instead of fetching them every time.
/Patrik
Version 2.0.5
Removing old code.
atatps_250754
Altocumulus
Altocumulus
Script is freakn' awesome! Works like a charm...Can't believe you got no feedback on the post. Spared me the grueling monotonous work of manual data group entry. Thank you, sir!
Thanks for the feedback. I find that in general people don't bother to do what you just did (just saying thanks). So thank you too, for the kind words! 🙂
Tom_185829
Hi Very nice script. Indeed it's very helpful. Could you please add search field for partitions list. When you have a lot of partitions searching is terrible, with additional field it will be very helpfull.
Regards. Tomek M.
Tom_185829
Hi again. Is anybody try this scripts on F5 ver. 13.1 I try use this but I don't see effects.
Thanks for informations.
Reards Tom
Dan_Bowman
Cirrus
Cirrus
I'd expect this is for v12.x only as v13 introduced a lot of new features and changes.
It would be great to see a v13 compatible version though! 🙂
I chose to only support v12 simply because I didn't have any v13 in use when I wrote it. However, most functions should work. It's not harder than changing a row actually. I'll add a "beta" if any of you wants to try?
Oh, and if you guys like the script, feel free to rate it. 🙂
Dan_Bowman
Cirrus
Cirrus
I'd be game to try a v13 beta and feed back any issues etc - thank you for your time and efforts!
Thanks Dan, much appreciated! I'm adding a feature that Tom requested now. Will update with that feature and a v13 beta tomorrow.
/Patrik
Version 2.0.7 Added partition filter at the top right corner
  • Simply write to filter the partition drop down menu.
  • Hitting enter while in the filter box activates the currently selected option.
  • Any filter entered is saved and re-entered upon partition change. So if you have a prefix in your partitions and only want to use with ie. partitions named "Bank-Backend", "Bank-Frontend" and "Bank-CDE" you can simply enter "Bank-".
Thanks to Tom for suggesting it.
Option to activate the script on v13
I think most of the features should work on v13 too but I have had no time to test them. If you're willing to help here I'd be very grateful. To activate, scroll down to the bottom of the setting section and change allow13 = false; to allow13 = true;.
Christmas edition is build in to the script
The previous implementation was a completely separate edition of the script. Which meant that if you wanted to enable it you'd have to switch the code and when you finally had enough snow you'd have to switch again. Annoying.
Instead, now a form would show up automatically in December where you can choose to activate or deactivate the Christmas theme.
For those real grinches out there (or 100% professional consultants wanting to keep thing legit):
Don't you worry, you can totally supress the theme by changing var allowChristmas = true; to var allowChristmas = false;. Can't promise Santa will bring you any presents if you do though.
And for Devcentral member Boneyard
A bit of an easter egg. If you set var alwaysChristmas = true; in the settings section you can enjoy the theme all year long. 🙂
tomek
Hi Last week I tested script in F5 version 13. I didn't see any issues. Work perffectly. I thank you very much especially for partition search.
Regards Tom
No problem, thanks for reporting in regarding the v13 things too. How about you Dan? Any news?
/Patrik
Dan_Bowman
Cirrus
Cirrus
Unfortunately I'm currently having a little fight with our company security guys over being able to install tampermonkey! Should hopefully be resolved soon!
The joys of working in a corporate environment... :o/
I can understand where they're coming from. But it's not like the code is obfuscated or automatically updated. However, Tampermonkey might be. Go sway them with some whiskey or, if that won't work perhaps a neck rub. Perhaps that'll scare them away. 🙂
/Patrik
atatps_250754
Altocumulus
Altocumulus
I've got a possible bug to report. I observed this in the previous version as well as after upgrading to 2.0.7. With the script simply enabled in my browser (Firefox), the WebUI will eventually crash and restart. Because of this I only run the script on the Standby node then sync the changes to the Active node to prevent any potential outages in prod.
This seems like a bad one. Never seen it myself and we are a whole bunch of people using the script at my previous work place.
I wonder, is your configuration very large, or the specs very low? Are you often using the Read Only partition?
The only part of the script that I can think of of the top of my head that could affect the UI is the pool status. Let me create a custom version for you removing the heavy parts.
If it makes you feel better until then I can also tell you that it's safe to restart the webui process as it's separates from tmm.
Get back to you.
/Patrik
atatps_250754
Altocumulus
Altocumulus
I'm not sure what constitutes large in the industry but my config contains north of 7000 objects. Specs seem to be fine as I haven't experienced any other performance issues.
Let's say a pool has 2 members, that would count as 3 items. A pool with 4 members counts as 5.
In that case, roughly how many do you have?
/Patrik
atatps_250754
Altocumulus
Altocumulus
I've got 2000 pools with 1500 nodes.
Wow, at least to me that's a big config.
Have you divided it into multiple partitions? If so, do you have any partitions that is super large?
I updated with a version that removes the pool status improvements from the pool list. Could you please see if that helped?
/Patrik
atatps_250754
Altocumulus
Altocumulus
I've got everything in the common partition.
Sure, how do I get a hold of the revised code?
Hi Atatps
Sorry about that, I forgot to click on the submit button. The code is there now. 🙂
/Patrik
atatps_250754
Altocumulus
Altocumulus
Thanks! No more crashing when viewing pools. When viewing an iRule and clicking on the data group under "Detected Data group lists", it just "loads" forever. It's no big deal but just an FYI.
Ran some quick tests on v14 and it works there too. 🙂
Take that back. Pool status is not working for v14. 🙂
/Patrik
Fixed.
/Patrik
youssef_100679
Nice Job Patrik!!!
TimRiker
The datagroup editing is very nice. "Replace current list" takes a very long time to complete with large datagroups (4000 lines).
TimRiker
Note: the updated beta has my performance improvements greatly reducing the "Replace current list" processing time. 🙂
TimRiker
I added BIG-IP v15.x support. Also v20 supports ":=" occurring inside the value side of a datagroup.
https://raw.githubusercontent.com/timriker/F5-UI-FrontendEnhancements/master/F5-Frontend-Enhancement...
Version history
Last update:
‎07-Dec-2017 23:57
Updated by:
Contributors
