SMTP Start TLS
Problem this snippet solves:
Summary: This iRule allows either clear text or TLS encrypted communication with the LTM initiating the encryption process if it sees the appropriate "starttls" command in the SMTP communication.
Code :
when CLIENT_ACCEPTED { set ehlo 0 SSL::disable } when SERVER_CONNECTED { TCP::collect } when CLIENT_DATA { set lcpayload [string tolower [TCP::payload]] if { $lcpayload starts_with "ehlo" } { set ehlo 1 serverside { TCP::collect } TCP::release TCP::collect } elseif { $lcpayload starts_with "starttls" } { TCP::respond "220 Ready to start TLS\r\n" TCP::payload replace 0 [TCP::payload length] "" TCP::release SSL::enable } else { TCP::release } } when SERVER_DATA { if { $ehlo == 1 and not([string tolower [TCP::payload]] contains "starttls") } { TCP::payload replace 0 0 "250-STARTTLS\r\n" } TCP::release clientside { TCP::collect } }
Published Mar 18, 2015
