Small URL Generator
Problem this snippet solves:
The Small URL Generator takes a long URL, examines its length, and assigns it a variable length key based on the original URL's length. The key is then stored in a subtable along with the original URL. When a user accesses the small URL (http:/// ), they are then redirected to the original long URL. This Small URL Generator also has the ability to create custom URL keys. Click here for the accompanying tech tip
Code :
when RULE_INIT { set static::small_url_timeout 86400 set static::small_url_lifetime 86400 set static::small_url_response_header " \\ $static::small_url_response_footer" } } }Small URL Generator " } when HTTP_REQUEST { if { ([HTTP::uri] starts_with "/create?") and ([HTTP::query] ne "") } { set url [URI::decode [string tolower [URI::query [HTTP::uri] url]]] set custom_url_key [string tolower [URI::query [HTTP::uri] custom_url_key]] if { $custom_url_key ne "" } { if { ([table lookup -subtable small_url $custom_url_key] ne "") } { HTTP::respond 200 content "$static::small_url_response_header \ Error: the custom Small URL \ http://[HTTP::host]/$custom_url_key has already been taken. Please try again. \ $static::small_url_response_footer" } else { set url_key $custom_url_key log local0. "Custom Small URL created for $url with custom key $url_key" } } else { switch -glob [string length $url] { {[1-9]} { set url_key_length 3 } {1[0-9]} { set url_key_length 3 } {2[0-9]} { set url_key_length 4 } {3[0-9]} { set url_key_length 5 } default { set url_key_length 6 } } set url_key [string tolower [scan [string map {/ "" + ""} [b64encode [md5 $url]]] "%${url_key_length}s"]] } if { ([table lookup -subtable small_url $url_key] eq "") } { table add -subtable small_url $url_key $url $static::small_url_timeout $static::small_url_lifetime log local0. "Small URL created for $url with key $url_key" } else { log local0. "Small URL for $url already exists with key $url_key" } HTTP::respond 200 content "$static::small_url_response_header The Small URL for \ $url is \ http://[HTTP::host]/$url_key $static::small_url_response_footer" } else { set url_key [string map {/ ""} [HTTP::path]] set url [table lookup -subtable small_url $url_key] if { [string length $url] != 0 } { log local0. "Found key $url_key, redirecting to $url" HTTP::redirect $url } else { HTTP::respond 200 content "$static::small_url_response_header Small URL Generator
\ " set static::small_url_response_footer "
Published Mar 18, 2015
