JackofallTrades
Historic F5 Account
Problem this snippet solves:
This script is for adding Wide_IPs
Code :
import pycontrol.pyControl as pyControl
#Create the BigIP object
b = pyControl.BIGIP(hostname   = '10.10.10.10',
    username   = 'admin',
    password   = 'admin',
    wsdl_files = ['GlobalLB.WideIP']
#Creat the WideIP,LB_Method and add pools. here we are setting the ratios for the pools
d = b.GlobalLB_WideIP
try:
d.create(
              wide_ips = ['www.pycontrol.com'],
    lb_methods = ['LB_METHOD_GLOBAL_AVAILABILITY'],
  wideip_pools = [[{'order': 1, 'pool_name': 'pypool1', 'ratio': 1}]],
  wideip_rules = []
print "WideIP was Created."
except:print "WideIPcreate error. Check log."
#### This is the section where we are adding an alias to the WideIP.
try:
d.add_alias(
      aliases  = [['ww2.pycontrol.com',
                           'ww3.pycontrol.com',
                          'ww4.pycontrol.com',
                           'www.foo.com']]
print "WideIP-Alias was Created."
except:print "WideIP aslias create error. Check log.
Version history
Last update:
‎09-Mar-2015 12:24
Updated by:
Contributors
