Perl PoolMember Monitor
Problem this snippet solves:
This sample illustrates how to get and set a monitor association with a pool member.
Code :
#!/usr/bin/perl #---------------------------------------------------------------------------- # The contents of this file are subject to the iControl Public License # Version 9.2 (the "License"); you may not use this file except in # compliance with the License. You may obtain a copy of the License at # http://www.f5.com/. # # Software distributed under the License is distributed on an "AS IS" # basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See # the License for the specific language governing rights and limitations # under the License. # # The Original Code is iControl Code and related documentation # distributed by F5. # # The Initial Developer of the Original Code is F5 Networks, # Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2011 # F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered # trademark of F5 Networks, Inc. # # Alternatively, the contents of this file may be used under the terms # of the GNU General Public License (the "GPL"), in which case the # provisions of GPL are applicable instead of those above. If you wish # to allow use of your version of this file only under the terms of the # GPL and not to allow others to use your version of this file under the # License, indicate your decision by deleting the provisions above and # replace them with the notice and other provisions required by the GPL. # If you do not delete the provisions above, a recipient may use your # version of this file under either the License or the GPL. #---------------------------------------------------------------------------- use strict; use warnings; $ENV{PERL_LWP_SSL_VERIFY_HOSTNAME} = 0; #use SOAP::Lite + trace => qw(method debug); use SOAP::Lite; #---------------------------------------------------------------------------- # Validate Arguments #---------------------------------------------------------------------------- my $sHost = $ARGV[0]; my $sUID = $ARGV[1]; my $sPWD = $ARGV[2]; my $sPool = $ARGV[3]; my $sMember = $ARGV[4]; my $sMonitor = $ARGV[5]; sub usage() { die ("Usage: PoolMemberMonitor.pl host port uid pwd [pool [member:port [monitor]]]\n"); } if ( !defined($sHost) or !defined($sUID) or !defined($sPWD) ) { usage(); } #---------------------------------------------------------------------------- # Transport Information #---------------------------------------------------------------------------- sub SOAP::Transport::HTTP::Client::get_basic_credentials { return "$sUID" => "$sPWD"; } #---------------------------------------------------------------------------- # GetInterface #---------------------------------------------------------------------------- sub GetInterface() { my ($name) = (@_); my $Interface = SOAP::Lite -> uri("urn:iControl:$name") -> readable(1) -> proxy("https://$sHost/iControl/iControlPortal.cgi"); # $Interface->set_opt(verify #---------------------------------------------------------------------------- # Attempt to add auth headers to avoid dual-round trip #---------------------------------------------------------------------------- eval { $Interface->transport->http_request->header ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '') ); }; return $Interface; } my $Pool = &GetInterface("LocalLB/Pool"); my $PoolMember = &GetInterface("LocalLB/PoolMember"); #---------------------------------------------------------------------------- # support for custom enum types #---------------------------------------------------------------------------- sub SOAP::Deserializer::typecast { my ($self, $value, $name, $attrs, $children, $type) = @_; my $retval = undef; if ( defined($type) && "{urn:iControl}Common.EnabledState" eq $type ){ $retval = $value; } return $retval; } #---------------------------------------------------------------------------- # Main logic #---------------------------------------------------------------------------- if ( !defined($sPool)||$sPool eq '' ) { &getPoolList(); } elsif ( "" eq $sMember ) { &getPoolMembers($sPool); } elsif ( "" eq $sMonitor ) { &getPoolMemberMonitors($sPool, $sMember); } else { &setPoolMemberMonitor($sPool, $sMember, $sMonitor); } sub getPoolList() { my $soapResponse = $Pool->get_list(); &checkResponse($soapResponse); my @pool_list = @{$soapResponse->result}; print "AVAILBLE POOLS\n"; foreach my $pool (@pool_list) { print "$pool\n"; } } sub getPoolMembers() { my ($pool) = (@_); my $soapResponse = $Pool->get_member( SOAP::Data->name(pool_names => [$pool]) ); &checkResponse($soapResponse); my @memberListAofA = @{$soapResponse->result}; # Extract the 1st list for the single pool passed in. my @memberListA = @{$memberListAofA[0]}; print "POOL '$pool' members\n"; # build parameters for set_session_enabled_state(); foreach my $member_def (@memberListA) { my $address = $member_def->{"address"}; my $port = $member_def->{"port"}; print " ${address}:${port}\n"; } } sub getPoolMemberMonitors() { my ($pool, $member) = (@_); my ($addr, $port) = split(/:/, $member, 2); my $soapResponse = $PoolMember->get_monitor_association( SOAP::Data->name(pool_names => [$pool]) ); &checkResponse($soapResponse); my @MonitorAssociationAofA = @{$soapResponse->result}; my @MonitorAssociationA = @{$MonitorAssociationAofA[0]}; print "POOL '$pool' monitors\n"; foreach my $MonitorAssociation (@MonitorAssociationA) { my $MonitorIPPort = $MonitorAssociation->{"member"}; my $atype = $MonitorIPPort->{"address_type"}; my $ipport = $MonitorIPPort->{"ipport"}; my $addr = $ipport->{"address"}; my $port = $ipport->{"port"}; my $MonitorRule = $MonitorAssociation->{"monitor_rule"}; my $type = $MonitorRule->{"type"}; my $quorum = $MonitorRule->{"quorum"}; print " ${addr}:${port} - ${atype}\n"; print " Type: ${type}, Quorum: ${quorum}\n"; my @monitor_templates = @{$MonitorRule->{"monitor_templates"}}; foreach my $monitor_template (@monitor_templates) { print " $monitor_template\n"; } } } sub setPoolMemberMonitor() { my ($pool, $member, $monitor) = (@_); my ($addr, $port) = split(/:/, $member, 2); my $IPPortDefinition = { address => $addr, port => $port }; my $MonitorIP = { address_type => "ATYPE_EXPLICIT_ADDRESS_EXPLICIT_PORT", ipport => $IPPortDefinition }; my $MonitorRule = { type => "MONITOR_RULE_TYPE_SINGLE", quorum => 0, monitor_templates => [$monitor] }; my $MonitorAssociation = { member => $MonitorIP, monitor_rule => $MonitorRule }; my (@MonitorAssociationA,@MonitorAssociationAofA); push @MonitorAssociationA, $MonitorAssociation; push @MonitorAssociationAofA, [@MonitorAssociationA]; my $soapResponse = $PoolMember->set_monitor_association( SOAP::Data->name(pool_names => [$pool]), SOAP::Data->name(monitor_associations => [@MonitorAssociationAofA]) ); &checkResponse($soapResponse); &getPoolMemberMonitors($pool, $member); } #---------------------------------------------------------------------------- # checkResponse #---------------------------------------------------------------------------- sub checkResponse() { my ($soapResponse) = (@_); if ( $soapResponse->fault ) { print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n"; exit(); } }
Published Mar 08, 2015
