Migrate BigIP Configuration - using f5-sdk and python
Problem this snippet solves:
I came across a situation where I need to replace Old BigIP unit with a newer one.
I have decided to use python and f5-sdk to read all the different bigip components from source unit and deploy on the destination unit and then compare the config.
I have put all the code on github.com as : https://github.com/mshoaibshafi/f5-networks-bigip-migrate-configuration
How to use this snippet:
The code is as modular as possible and you can start from the file name "Main.py"
It follows the following sequence :
- Migrate Monitors
- Migrate Pools
- Migrate Virtuals
- Migrate Users
- Compare Configuration
Code :
GitHub.com Repo : https://github.com/mshoaibshafi/f5-networks-bigip-migrate-configuration
Tested this on version:
12.1Published May 06, 2019
