JRahm
Community Manager
Community Manager
Problem this snippet solves:
This script uses iControl REST with the options query parameter to pass records data to the tmsh command for data-groups so individual records can be added/modified/removed since the records themselves are not a subcollection.
There are two versions of this script, one requiring a tmsh script, and one without. The only without is the recommended path, but I include both here for educational purposes on how one might use tmsh scripts and iControl REST in other projects.
How to use this snippet:
% python dgmgmt.py -h
usage: dgmgmt.py [-h] host user {add,modify,delete} datagroup dgvalues
positional arguments:
  host                 BIG-IP IP/FQDN
  user                 BIG-IP Username
  {add,modify,delete}  add | modify | delete
  datagroup            Data-Group name you wish to change
  dgvalues             Key or KV Pairs, in this format: "k1,k2,k3=v3,k4=v4,k5"
optional arguments:
  -h, --help           show this help message and exit
Tested this on version:
No Version Found
Version history
Last update:
‎08-Jan-2021 20:21
Updated by:
Contributors
