Problem this snippet solves:
www.example.xyz/sd/test/sd?pid=http://testssd.xyz&target=http://testesd.xyz
I need to write regexp pattern to get value of target=http://testesd.xyz
and redirect to
www.sub.example.xyz/sd/test/disd?dest=http://testesd.xyz
Code :
Hi, I need help with writing irule for this case:
and redirect to
Comments
Stanislas_Piro2
Cumulonimbus
Cumulonimbus
you are in the wrong part of the forum...
post your question in Answers section.
Version history
Last update:
‎28-Oct-2016 02:40
Updated by:
Contributors
