on 22-Dec-2016 13:22
Problem this snippet solves:
This is a python module to simplify using iControl REST.
Install using pip:
pip install iCR
or retrieve from https://pypi.python.org/pypi?:action=display&name=iCR&version=2.1
As simple as:
#!/usr/bin/env python
from iCR import iCR
bigip = iCR("172.24.9.132","admin","admin")
virtuals = bigip.get("ltm/virtual")
for vs in virtuals['items']:
print vs['name']
This prints out a list of Virtual Servers.
Supported methods:
init(hostname,username,password,[timeout,port,icontrol_version,folder,token,debug])
get(url,[select,top,skip,filter])
-> returns data or Falsegetlarge(url,size,[select])
-> Used to retrieve large datasets in chunks. Returns data or Falsecreate(url,data)
-> returns data or Falsemodify(url,data,[patch=True])
-> returns data or Falsedelete(url)
-> returns True or Falseupload(file)
-> file is a local file eg /var/tmp/test.txt, returns True or Falsedownload(file)
-> files are located in /shared/images, returns True or Falsecreate_cert(files)
-> files is an array containing paths to cert and key. Returns name of cert or Falseget_asm_id(name)
-> name is the name of a policy. Returns an array of IDs or Falsecreate_hash(name)
-> name is the name of the partition and policy. eg /Common/test_policy. This reduces the need to retrieve an array of hashes from the BIG-IP. Returns a string.get_token()
-> this retrieves a BIG-IP token based on the username and password and sets it as the token in use. Returns the token ID or Falsedelete_token()
-> This deletes the object token from the BIG-IP and from the object
Module Variables:
How to use this snippet:
Setup a REST connection to a device
from iCR import iCR
bigip = iCR("172.24.9.132","admin","admin",timeout=10)
Create a Virtual Server
vs_config = {'name':'test_vs'}
createvs = bigip.create("ltm/virtual",vs_config,timeout=5)
Retrieve the VS we just created
virt = bigip.get("ltm/virtual/test_vs",select="name")
print "Virtual Server created: " + virt['name']
Set the timeout
bigip.timeout = 20
Now delete the VS we just created
delvs = bigip.delete("ltm/virtual/test_vs")
Retrieve ASM policy to ID mapping
policies = bigip.get("asm/policies",select="name,id")
Print a table of ASM policies with learning mode
print
print "Policy Name Learning Mode"
print "------------------------------------------"
for item in policies['items']:
enabled = bigip.get("asm/policies/" + item['id'] + "/policy-builder",select="learningMode")
print '{:32}'.format(item['name']) + enabled['learningMode']
File upload
fp = "/home/pwhite/input.csv"
if bigip.upload(fp):
print "File " + fp + " uploaded"
File download
file="BIGIP-12.1.2.0.0.249.iso"
download = bigip.download(file)
if not download:
print "File " + file + " download error"
SSL Certificate creation
In different folder
bigip.folder = "TestFolder"
files = ("TestCert.crt","TestCert.key")
cert = bigip.create_cert(files)
if cert:
print "Certificate " + cert + " created"
Turn on debugging
bigip.debug = True
Retrieve ASM policy IDs
asm = bigip.get_asm_id("dummy_policy")
print len(asm) + " IDs returned"
print "ID: " + str(asm[0])
Convert an ASM policy name to hash
hash = bigip.create_hash("/Common/test-policy")
enabled = bigip.get("asm/policies/" + hash + "/policy-builder",select="learningMode")
Retrieve and use a token
bigip.get_token()
Delete the token
bigip.delete_token()
Developed on Python 2.7 but works with v3. Works on TMOS 11.6 onwards though some features may not be implemented, such as tokens. If you use this and have found bugs, would like to discuss it or suggest features then please PM me on DevCentral.
Tested this on version:
13.0Hey Pete, I'm looking to upload SSL certificate and key, then add them to a virtual server, we're using the Python SDK, any thoughts?
Yes, this is fairly simple - see here and here for uploading files via REST and adding of certs/keys are detailed at https://devcentral.f5.com/s/feed/0D51T00006i7Y3KSAU
Obviously you'd have to create the f5sdk commands for those URLs. Because f5sdk doesn't expose the http method directly but uses CURDLE methods so you would have to select the correct method to match your requirements. For instance you would probably use the create() method to use the POST HTTP method.
fantastic your last comment helps clarify things.
it seems that the certificate should be on the host before I upload it, is there a way to upload it directly from my laptop?
Also.. THANK YOU for the prompt response.
You can upload it to the BIG-IP using iControl REST or just use scp which may be simpler. Then create the SSL certs, SSL profile and add it to the VS.
I will think about adding a function to the iCR module to upload or download a file. Might come in handy
Tried the "as simple as" code at the top that prints the virtual server names and I got the following error: TypeError: 'module' object is not callable. Debugging shows that the line of code throwing the error is "bigip = iCR("yadda", "yadda", "yadda")", with iCR being the module object that isn't callable.
Thoughts?
Also, I'm using Python 2.7. I have been using the f5-sdk package to date and doing what the sample script above does works without issue.
Hey Pete, For whatever reason, an error occurs every time I try to send you a direct message. Errors using iCR, errors trying to send messages on this site... maybe it's me? lol
Can you try sending me a message and I'll see if I can reply successfully to it?
Hey Pete, I decided to check out iCR once more and I used the "as simple as" example you posted above but I kept getting this error: "TypeError: 'module' object is not callable".
I did some digging on the error and per Stack Exchange, the error is caused because the iCR module you import and the iCR class you instantiate are the same name.
To instantiate the iCR class successfully, I updated your sample code to
bigip = iCR.iCR("172.24.9.132","admin","admin")
That is the only way I can run the code in Python 2.7.14 without error.
I've updated the module to add some functionality like uploading and downloading files as well as creating SSL certs and profiles, and retrieving an ASM ID from a policy name. Feel free to try it out and let me know what you think.
Hi liuyi6324, I have developed and tested this on Python 2 but i can't see why it wouldn't work on v3. The only issue might be the debug I guess - print is different in v3. If you can test it and let me know I will develop it so that it works in v3 as well. This will work in all versions after 11.5 as it uses the basic REST functionality.
