iControlREST: Ruby: To Output a List of Virtual Servers and their Associated Pools and Pool Members.
Problem this snippet solves:
This script enumerates virtual servers and their associated pools and pool members and their status, each virtual server on a line of its own in the ";' delimited format. Essentially, the code shows a way to parse the 'ltm/virtual' object and get the information required. It had a specific need to address when it was written, and it can be modified to suit other similar requirements.
How to use this snippet:
This code has been tested with Ruby 2.3.1p112.
Code :
#!/usr/local/bin/ruby -w # # This script enumerates virtual servers and their associated pools and # pool members and their status, each virtual server on a line of its own # in the ";' delimited format. # #------------------------------------------------------------------------- require 'rubygems' require 'rest-client' require 'json' # define program-wide variables BIGIP_ADDRESS = 'mgmt_IP_addr' BIGIP_USER = 'admin' BIGIP_PASS = 'admin' SLEEP_TIME = 20 bigip = RestClient::Resource.new( "https://#{BIGIP_ADDRESS}/mgmt/tm/", :user => BIGIP_USER, :password => BIGIP_PASS, :headers => { :content_type => 'application/json' }, :verify_ssl => false ) # Get virtual servers: vservers = bigip['ltm/virtual'].get vservers_obj = JSON.parse(vservers) # Get pools: pools = bigip['ltm/pool?expandSubcollections=true'].get pools_obj = JSON.parse(pools) # Output header: puts "Virtual Server Name;Virtual Server Destination;Virtual Server Partition;Pool Name;Pool LB Mode;Pool Member Name (address)(state)" $output = '' # Process data: vservers_obj.each do |vserver_obj| vserver_obj.each do |vserver_obj_element| if vserver_obj_element.is_a?(Array) vserver_obj_element.each do |vserver_obj_element_property| if vserver_obj_element_property.is_a?(Hash) if vserver_obj_element_property.has_key?("name") vs_name = vserver_obj_element_property.fetch("name") $output = $output + vs_name + ';' end if vserver_obj_element_property.has_key?("destination") vs_destination = vserver_obj_element_property.fetch("destination") $output = $output + vs_destination + ';' end if vserver_obj_element_property.has_key?("partition") vs_partition = vserver_obj_element_property.fetch("partition") $output = $output + vs_partition + ';' end if vserver_obj_element_property.has_key?("pool") pool_name_from_vs = vserver_obj_element_property.fetch("pool") pools_obj.each_pair do |key, val| next if key == "kind" next if key == "selfLink" for x in 0..(val.length-1) if val[x]["fullPath"] == pool_name_from_vs $output = $output + val[x]["name"] + ";" + val[x]["loadBalancingMode"] if val[x].has_key?("membersReference") val[x]["membersReference"].each_pair do |mrefkey,mrefval| next if mrefkey == "link" next if mrefkey == "isSubcollection" for i in 0..(mrefval.length-1) if i == 0 $output = $output + ";" + mrefval[i]["name"] + "(" + mrefval[i]["address"] + ")(" + mrefval[i]["state"] + ")," else $output = $output + mrefval[i]["name"] + "(" + mrefval[i]["address"] + ")(" + mrefval[i]["state"] + ")," end if i == mrefval.length-1 $output.chop! $output += "\n" end end end else $output = $output + ";;\n" end break end end end else $output = $output + ";;\n" end end end end end end puts $output #---END---
Tested this on version:
11.6Published Aug 06, 2016
