hooleylist
Problem this snippet solves:
Here is an updated version of the iRule from this post and techtip.
Mitigating Slow HTTP Post DDoS Attacks With iRules – Follow-up https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1174748/showtab/groupforum...
This past week researchers demonstrated a new HTTP DDoS attack in which a slow POST request will result in leaving a connection open longer than necessary. The heart of the attack relies on sending a POST request with given “content-length” then very slowly sending the POST message body to the server. The server will leave the connection open as it continues to receive data. If a large number of these requests are executed against a server, there is potential for exhausting the connection table leaving the server unable to respond to further requests.
There are a few different ways to mitigate such an attack using iRules. You could build a list of all the URLs that require POST requests and only allow requests for these URLs. This method while effective against a blanket attack would prove ineffective against an attacker who was targeting a page that relies on legitimate POST requests. Aside from that, someone must maintain the list. Enter the “after” command…
The after command was introduced in version 10 of BIG-IP and allows among other things, the cancellation of a previous script. In this example, if our client is sending their POST request too slowly we will instruct our BIG-IP to send them a HTTP 500 error and close the connection after a given period. If their request is received within the allotted time period, we will cancel our previous instruction and allow the connection to them proceed to the origin servers.
Code :
# Based on 'Mitigating Slow HTTP Post DDoS Attacks With iRules' from George Watkins
# Requires LTM v10.0+ for the after command
when RULE_INIT {
   # This iRule enforces a minimum length of time ($static::timeout) for a client to send POST request data.
   # The initial values are 2Kb / 2 sec = 1 Kb/s for the first 2Kb.  These values should be tailored for the client base.
   # Default amount of request payload to collect (in bytes).
   # This is the maximum amount of content we will collect.
   # Clients will still be able to send unlimited payload sizes.
   set static::collect_length 2048
   # Default timeout, for POST requests, to send $collect_length bytes (in milliseconds)
   set static::timeout 2000
   # HTML response to send for blocked requests
   set static::block_html {Your POST request is not being received quickly enough. Please retry.}
   # Log debug messages to /var/log/ltm? 1=yes, 0=no.
   set static::post_debug 1
   # Only check POST requests. If the application supports other request methods with payloads, add them in a switch statement here.
   if { [HTTP::method] equals "POST"} {
      if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: POST to [HTTP::host][HTTP::uri]" }
      # Create a local variable copy of the collection amount
      set collect_length $static::collect_length
      # Create a local variable copy of the static timeout
      set timeout $static::timeout
      # Check for a non-existent Content-Length header
      if {[HTTP::header Content-Length] eq ""}{
         # Use default collect length for POSTs without a Content-Length header
         if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: No Content-Length value" }
      } elseif {[HTTP::header Content-Length] <= 0}{
         # Don't try to collect a payload if there isn't one
         unset collect_length
         if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: Content-Length: 0." }
      } elseif {[HTTP::header Content-Length] > $static::collect_length}{
         # Use the default collect length
         if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: Content-Length: [HTTP::header Content-Length], collecting $collect_length" }
         # Collect the actual payload length
         set collect_length [HTTP::header Content-Length]
         # Calculate a custom timeout based on the same ratio we use for the default collect length and default timeout
         set timeout [expr {[HTTP::header Content-Length] * $static::timeout / $static::collect_length }]
         if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: Content-Length: [HTTP::header Content-Length], collecting $collect_length bytes with timeout $timeout ms" }
      # If the POST Content-Length isn't 0, collect (a portion of) the payload
      if {[info exists collect_length]}{
         # If the entire request hasn't been received within X seconds, send a 408, and close the connection
         set id [after $timeout {
            if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: $timeout ms reached. Closing connection" }
            HTTP::respond 408 content $static::block_html Connection Close
            TCP::close
         # Trigger collection of the request payload
         HTTP::collect $collect_length
         if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: Collecting $collect_length" }
when HTTP_REQUEST_DATA {
   if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: Collected [HTTP::payload length] bytes." }
   # Check if the 'after' ID exists
   if {[info exists id]} {
      # If all the POST data has been received, cancel the connection closure
      if { $static::post_debug } { log local0. "[IP::client_addr]:[TCP::client_port]: Canceling \$id: $id" }
      after cancel $id
      # This needs to be reworked to address ID454692
      # unset id
Comments
sthussey_131917
Are there any concerns about race conditions for Keep-Alive connections? It seems the 'id' variable is scoped to the TCP connection. If we get request A and begin data collection (and therefore initiated the 'after' call with id 1) and before the collection is finished, we receive request B and collection is started and another 'after' call is started with id 2. When HTTP_REQUEST_DATA is called for the collection of request A, wouldn't $id now be 2 and therefore the cancellation call for the after event 1 would not happen. Could this cause termination of valid connections in some edge cases? Edit: I over thought it. HTTP 1.1 doesn't allow concurrent outstanding requests over a single connection, so no race condition.
Version history
Last update:
‎18-Mar-2015 11:47
Updated by:
Contributors
