JRahm
Community Manager
Community Manager
Problem this snippet solves:
This script uploads, installs, and verifies the three toolchain components: declarative onboarding, as3, and telemetry streaming.
Note: bip.py in BIGREST must be modified to allow 202 response codes. The author will have this fixed in the next release, but you will need to modify line 183 in big.py:
if response.status_code != 200 and response.status_code != 201 and response.status_code != 202:
How to use this snippet:
python toolchain_prep.py 10.0.2.26 admin admin
Instantiating BIG-IP (host 10.0.2.26)
Uploading packages
        Uploading f5-declarative-onboarding-1.20.0-2.noarch.rpm
        Uploading f5-appsvcs-3.27.0-3.noarch.rpm
        Uploading f5-telemetry-1.19.0-3.noarch.rpm
Installing packages
        Installing f5-declarative-onboarding-1.20.0-2.noarch.rpm
        Installing f5-appsvcs-3.27.0-3.noarch.rpm
        Installing f5-telemetry-1.19.0-3.noarch.rpm
Quick break to register packages...
Verifying packages
        f5-declarative-onboarding-1.20.0-2.noarch.rpm installed and verified
        f5-appsvcs-3.27.0-3.noarch.rpm installed and verified
        f5-telemetry-1.19.0-3.noarch.rpm installed and verified
---complete---
Tested this on version:
No Version Found
Version history
Last update:
‎05-May-2021 09:11
Updated by:
Contributors
