Create an Internet exposed HTTPS Load-Balancer on Volterra with Terraform (Origin handled by a Volterra node)
Problem this snippet solves:
How to create an Internet exposed HTTPS Load-Balancer with VoltMesh where the Origin is reachable through a Volterra node. The Origin is HTTP based but will be exposed on the Internet over HTTPS.
Two steps are needed:
- Creation of the Origin (1-origin.tf file)
- Creation of the Load-Balancer (2-https-lb.tf file)
How to use this snippet:
Pre-requirements:
- Have a Volterra API Certificate. Please see this page for the API Certificate generation: https://volterra.io/docs/how-to/user-mgmt/credentials
- Extract the certificate and the key from the .p12:
openssl pkcs12 -info -in certificate.p12 -out private_key.key -nodes -nocerts openssl pkcs12 -info -in certificate.p12 -out certificate.cert -nokeys
- Create a variables.tf Terraform variables file:
variable "api_cert" { type = string default = "/<full path to>/certificate.cert" } variable "api_key" { type = string default = "/<full path to>/private_key.key" } variable "api_url" { type = string default = "https://<tenant_name>.console.ves.volterra.io/api" }
- Create a main.tf Terraform file:
terraform { required_version = ">= 0.12.9, != 0.13.0" required_providers { volterra = { source = "volterraedge/volterra" version = ">=0.0.6" } } } provider "volterra" { api_cert = var.api_cert api_key = var.api_key url = var.api_url }
- Encode in base 64 the public key of the TLS certificate you want to use in the HTTPS load-balancer, From a shell, run:
base64 publicpart_of_tls_certificate.pem
- Get the Volterra vesctl tool: https://gitlab.com/volterra.io/vesctl/blob/main/README.md
- Then in your home directory, create a .vesconfig file with the following lines:
server-urls: https://<tenant>.console.ves.volterra.io/api key: /<full path to>/private_key.key cert: /<full path to>/certificate.cert
- Then in the folder where you have installed vesctl, run:
./vesctl.darwin-amd64 request secrets get-public-key > tenant-public-key ./vesctl.darwin-amd64 request secrets get-policy-document --namespace shared --name ves-io-allow-volterra > ves-io-allow-volterra-policy ./vesctl.darwin-amd64 request secrets encrypt --policy-document ves-io-allow-volterra-policy --public-key tenant-public-key privkey.pem > blindfolded-privkey
Where privkey.pem is the private key of your TLS certificate. The Volterra encrypted TLS key will be available in the blindfolded-privkey file.
In the directory where your terraform files are, run:
terraform init
Then:
terraform apply
Code :
//========================================================================== //Definition of the Origin, 1-origin.tf //Start of the TF file resource "volterra_origin_pool" "sample-https-origin-pool" { name = "sample-https-origin-pool" //Name of the namespace where the origin pool must be deployed namespace = "mynamespace" origin_servers { private_ip { ip = "10.17.20.13" //From which interface of the node onsite the IP of the service is reachable. Value are inside_network / outside_network or both. outside_network = true //Site definition site_locator { site { name = "name-of-the-site" namespace = "system" tenant = "name-of-the-tenant" } } } labels = { } } no_tls = true port = "80" endpoint_selection = "LOCALPREFERED" loadbalancer_algorithm = "LB_OVERRIDE" } //End of the file //========================================================================== //========================================================================== //Definition of the Load-Balancer, 2-https-lb.tf //Start of the TF file resource "volterra_http_loadbalancer" "sample-https-lb" { depends_on = [volterra_origin_pool.sample-https-origin-pool] //Mandatory "Metadata" name = "sample-https-lb" //Name of the namespace where the origin pool must be deployed namespace = "mynamespace" //End of mandatory "Metadata" //Mandatory "Basic configuration" domains = ["mydomain.internal"] https { add_hsts = true http_redirect = true tls_parameters { no_mtls = true tls_config { default_security = true } tls_certificates { certificate_url = "string:///" } secret_encoding_type = "EncodingNone" } } } } default_route_pools { pool { name = "sample-https-origin-pool" namespace = "mynamespace" } weight = 1 } //Mandatory "VIP configuration" advertise_on_public_default_vip = true //End of mandatory "VIP configuration" //Mandatory "Security configuration" no_service_policies = true no_challenge = true disable_rate_limit = true disable_waf = true //End of mandatory "Security configuration" //Mandatory "Load Balancing Control" source_ip_stickiness = true //End of mandatory "Load Balancing Control" } //End of the file //==========================================================================
Tested this on version:
No Version FoundPublished Oct 15, 2021
