Zero Hop Counts
Hello all. I have a BIG-IP 6400 running version 9.4.5 HF2. When I go to Main>Statistics>Global Traffic then select “Paths” in the Statistics Type drop down I receive output, but the “Hops” Current and Average numbers are all Zero’s.
I have checked the metrics collection settings and they are all at their defaults. I thought I might be having a problem with the statsd daemon, but I have valid performance graph information under the performance tab.
Any ideas as to why the hop counts would show up as zero?
Interesting…Can you pull the same same stats on the CLI?
CB
