XML base64 namespace and attack signatures
I have a XML/SOAP application where ASM causes a high number of false positives on the attack signatures.
The main culprit is a namespace which is base64 encoded (embedded picture) where the combination of characters often matches a signature.
Is there a way to disable/unblock signatures when they creates a violation on this specific namespace?
I was thinking of fixing up an iRule but I don’t know how to make the match between the namespace and a signature violation.
do you have a XML profile attached? does it recognize the name space as variable?
Hmm didn’t think of that.
I’ve only used the WSDL file.
I still don’t see how I can match the signature violation with the element?
