Kunja thanks for your response . But when I changed my proxy VIP from fastl4 profile to http profile and added this irule. now when i change my proxy to point to the vip on port 8080 .
it is all internet traffic ,so it might be http or https. ssl offload is not performed on the F5 ,and also backend pool members have is very limited for https traffic
I created VIP type as performance(layer4) Protocol All protocols Protocol Profile (Client) : fastl4 Sourec Address Translation : Automap Persistence : source address vlan and tunnel traffic : ALL Vlans
In order for me to add irule ,i need to change the profile type to either http or fasthttp but it is breaking the connections.
If you are not doing ssl offload, you cannot use L7 iRules for the ssl traffic - like the one above.
Are you intending to use the same virtual server for both unencrypted and encrypted traffic? That would make the virtual server iRule a bit complicated as you have to detect ssl handshake to distinguish between those two traffic types. Anyway, if you want to do anything on Layer 7 (like the XFF insertion) for the ssl traffic, you must terminate SSL on the BIG-IP, so open up the encryption. You can then re-encrypt towards the backend servers.
Is it possible to use two virtual servers, same IP, different ports, one for unencrypted and the other for encrypted traffic? Keep in mind that the virtual server is a combination of IP and port, typically port 80 for plain text http and 443 for ssl. You can tie the same iRule to both.
Or are you intending to use BIG_IP as a proxy server (as you are looking for the CONNECT method)? So converting the traffic to tunnel the ssl through?
