XenDesktop Monitor for LTM
Here is a link to a couple monitors that can be used in conjunction with F5 LTM load-balancing XenDesktop infrastructure using versions 10.2 and above:
That is a wonderful script, with one exception, it has a hard coded host header.
This post looks like exactly the same thing that is sent to the XML broker which a Web interface would talk to. I do not have access to a Citrix environment right now but it would be interesting to see if the SID replacement of the user’ password would work for this monitor too.
