Hello According to this document (http://www.f5.com/pdf/deployment-guides/citrix-vdi-iapp-v1\_1-dg.pdf) it’s needed Hotfix-BIGIP-11.5.1.3.5.131-HF3-ENG.iso to make f5.citrix_vdiv1.1.0 template work with XenApp 7.5 and StoreFront 2.5 As 11.5.1 HF4 has been released, I would like to know if that version would be valid too, or it’s still needed the Enginnering Hotfix. Regards
Hi Manual,
You require the EngHF as that fix wasn’t rolled into HF4. You only need EngHF if they want to use HTML5 client in StoreFront 2.5 and/or SmartAccess filters.
Cheers.
