Xenapp 6.5 IAPP
Hi, I am using the template citrix.vdi.v2.0.0 and its working to load balance my webinterfaces and xml brokers, but the f5 opens my citrix with https and then redirect it to the http xenapps.
Is it possible to only use http instead https at F5, I didn´t find this option at the template.
You can disable the strict updates under properties and modify the virtual server, change the port to 80 and remove the SSL configuration on the Client SSL profile.
