X-FORWARDED-FOR AND ERASING SNAT IP FROM APACACHE LOGS
I am using x-forwarded-for and the web server admins would like to not see the snat ip in the logs. Currently I see both the client and snat ip. The client being 208.97.218.10 and snat 10.128.254.13. Can something be done within the x4 profile? - “Request Header Erase”? I
Apache logs 208.97.218.10, 10.128.254.13 - - [08/Jul/2014:10:06:42 -0500] “GET /XXXXXX/ HTTP/1.1” 200 2313 “-” “Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.11 (KHTML, like Gecko) Chrome/23.0.1271.95 Safari/537.11”
208.97.218.10, 10.128.254.13 - - [08/Jul/2014:10:06:42 -0500] “GET /XXXXXX HTTP/1.1” 304 - “XXXXXX” “Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.11 (KHTML, like Gecko) Chrome/23.0.1271.95 Safari/537.11”
Apparently the below irule also did not work to clear the double entries:
when HTTP_REQUEST { if {[HTTP::header exists X-Forwarded-For]}{ HTTP::header replace X-Forwarded-For “[HTTP::header X-Forwarded-For], [IP::remote_addr]” } else { HTTP::header insert X-Forwarded-For [IP::remote_addr] } } }
The XFF header is a layer 7 object, while the SNAT address is a layer 4 value. You cannot use an iRule to change the SNAT address without altering routing and potentially defeating the reason you’re using SNAT in the first place.
I would suggest tailoring the Apache log config to ignore the source address, the %h LogFormat value, and perhaps replacing it with the XFF header value \“%{X-Forwarded-For}i\”
The admin tried the %h and mentioned there was a comma seperated value issue. The strange thing is I do not see this on other device vips:
146.180.106.231 - - [09/Jul/2014:14:04:45 -0500] “POST /XXXXXX HTTP/1.1” 200 1177 “XXXXXX” “Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)”
66.150.110.71 - - [09/Jul/2014:14:04:55 -0500] “POST /XXXXXX HTTP/1.1” 200 25 “xxxxxxxxxxxxxxxxxx” “Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)”
So what does it look like if you do something like this?
LogFormat "\"%{X-Forwarded-For}i\" %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat ""%{X-Forwarded-For}i\" %l %u %t \"%r\" %>s %b" common
Hi folks,
I am facing the same problem, where the XFF is working but I still receiving the selfip sometimes on the APACHE’s log.
Would you help me out with this?
Thank you, Gabriel Castro
You’re basically getting two different IP addresses in different data streams. One is coming from an HTTP header (layer 7) and the other at TCP/IP layer 3. If you don’t want the layer 3 address, then you need to configure your Apache logs to ignore this value.
if going through multiple proxies, the XFF will end up as a list instead of single IP. You’d need to split the list and select one of them (like NOT the self) and then do a header replace on XFF.
Related Info:
XFF returning multiple IPs
Using XFF to block IPs
