WUI dashboard doesn't work after run "modify sys httpd ssl-port 8443"
i’ve changed the default administration https port running “tmsh modify sys httpd ssl-port 8443”, everthing works fine, but when i try to access the dashboard i got the message “Unrecoverable communications error”, i’ve checked the request generated by the browser and it looks like the “.swf” objects still triyng to connect using port 443. there is any way to change this behavior?
SOL REFERENCE 404 Page not found | BIG-IP Documentation
BIG-IP 12.0.0 Build 0.0.606 Final
Chrome Network Debug:
Request URL**:https://A.B.C.D/mcpq/mcpq**
Request Headers
Provisional headers are shown
Content-Type:application/x-www-form-urlencoded
Origin:https://A.B.C.D:8443
Referer:https://A.B.C.D:8443/tmui/dashboard/MonitorDashboardModule.swf
Hello Juan,
I think the details of the issue you are seeing are captured in this SOL:
It would seem the fix is coming in a later Hotfix… Or set the management port back to 443.
