Hello;
We have several sites with SSO using the LTM as an IdP and SP. But we are getting the following error trying to use it with WorkDay (http://www.workday.com) and the LTM as IdP:
Error Processing Message: Signature is missing or does not refer to the entire message.
I tried back and forth but I can get it to work…
Please advise…
Thank you
Is it an error message from APM or workday?
could you have a look to /var/log/apm, saml use to be verbose in debug logs.
did you import workday sp setting on apm from Metadata or manually ? if manually you may need to adjust setting in the security tab of the SP connector definition.
manually. i have tried all combination. and workday are no so helpful.
