I have BIG-IP Version 4.5.10.
Can I add or modify cookie in HTTP header ?
You can insert cookies to requests using the header insert attribute on a pool. Example:
pool cookie_machine {
header insert "Cookie: kind=blueberry"
member 1.2.3.4:80
There is no way how to modify existing cookie. You cannot insert arbitrary Set-Cookie statements into responses, only loadbalancing cookies needed for cookie based persistence.
