Wireshark capture on a LACP trunk channel
Two of my physical BIG-IP interfaces [2.1 and 2.2] have been configured as a portchannel, How can I get a capture of the traffic going through that port channel?
For one single interface I use the following command: tcpdump -i 2.1 -s 65535 -w destination_file
What would be the command or procedure to get the traffic for 2.1 and 2.2 as LACP trunk interface?
Have you seen: K6546: Recommended methods and limitations for running tcpdump on a BIG-IP system
From the article: If the specified interface is a member of a trunk, tcpdump captures all traffic flowing through the trunk, not just the traffic traversing the specified interface.
Beware of the rate limitations when capturing traffic on a hardware interface.
I didn’t see in the article, but you can run the following to get a list of interfaces available for capture
tcpdump -D
