Hello,
I am currently building up a policy in manual mode. Due to the size of this application, it requires a fair bit of work to add all parameters to the policy. A lot of these parameters are in the following form;
PAR1
PAR2
iPAR1
iPAR2
PAR3
PAR4
PAR11
Does the automatic policy builder correctly build wildcard parameters with the numbers as a wildcard? Thanks.
Regards
Yes--but there is one important condition that must be met: If you are using automatic policy builder, and you would like to ASM to learn each unique parameter, you must select Comprehensive mode (as the policy type) when you build the policy in the Deployment Wizard. This will ensure that the learning method for parameters is Add All Entities. If you’ve already got a policy, you can still change the learning method for parameters to Add All Entities yourself.
