I have a service running that uses a range of ports both TCP and UDP. So I had created 2 VIPs one for TCP any and one for UDP any. Now, I need to point a new range of ports to a new pool. I’m trying to use the VIP IP address. If I create a new port-specific VIP will it take priority over the ANY VIP that already exists?
Hi @Stuewe , You’re exactly right, the most specific VIPs will be selected first. See this guide for a detailed breakdown and examples of different scenarios.
