I have my ASM policy set with selective learning for URLs. At enforce readiness page I have suggestedd URLs to add as explicit entities which I understand why they are there. But I also have posibility to enforce wildcard entity as it is on picture:
So, why do I have this entry to enforce and should I enforce it? As I understand selective learning you have wildcard by default and you are enforcing explicit entities.
It looks like your wildcard URLs are in staging which basically just means that when a URL matches the wildcard it can still learn from it but it won’t block any traffic. If you were to enforce the wildcard then it would start blocking traffic when there are URLs that match the wildcard and the traffic triggers a violation. The following manual chapter speaks about this a little bit in the “Adjusting the enforcement readiness period” section.
