Device 1 : #1 (Active)
Device 2 : #2 (Standby)
I performed a failover.
Active device running Failover script, but it fail.
There seems to be an abnormal operation on the secondary IP.
to assign both equipment 1 and 2 to equipment NIC 2.
I need reset the failover extention or get metadate(azure) information.
How can I?
Hi @Hooni_L , @Jeff_Giroux_F5 has an article with lightboards on Azure HA that might be helpful: https://community.f5.com/t5/technical-articles/lightboard-lessons-big-ip-deployments-in-azure-cloud/ta-p/284445. If that doesn’t help directly, drop Jeff a comment in the article and post back here on status. I’m out on vacation after today until Tuesday.
Hi @JRahm
I couldn’t find a solution from the data you gave me.
but I will try the following measures.
Clear the statusdb file:
1. In the Azure portal, go into the storage account ending with ‘data000’
2. Go to containers, “failover” container
3. Delete statusdb file
If using the cloud failover extension (assumed here) then take a look at the tshooting section in F5 CloudDocs. The Cloud Failover tshooting section talks about resetting state file and reviewing logs…
Also helps to know how you initially deployed the BIG-IP devices…using templates? Manually through marketplace then manually doing HA setup? Here’s a tshooting section from the ARM templates github repo…
I used ARM template gitbug repo(full stack).
