What items will sync with Failover?
Are you unable to synchronize interface and VLAN settings?
If time synchronization doesn’t work, can’t we synchronize by forced push?
ex: `tmsh run cm config-sync to-group device-group-1`
Interface and VLANs are not synchronized between device group members during a ConfigSync operation.
REF: myF5
To set the device as the synchronization leader of the device group and force the device to initiate the ConfigSync process, use the following command syntax (12.1.0 and later):
run cm config-sync force-full-load-push to-group <group name>
REF: myF5
