Why do you need a Diameter Routing Agent (DRA) in a VoLTE deployment?
This article was written by Peter Nas, Senior Solution Architect for the Traffix SDC
Operators have begun to get more and more serious around deploying VoLTE (Voice over LTE) in their networks. Since the announcements of VoLTE services from some Korean and US operators, others, particularly in Asia, North America and EMEA, have launched or are about to launch VoLTE (see GSA announcement of 17th Sep 2014: 71 operators in 36 countries investing in VoLTE deployments, studies or trials, 10 operators commercially launched HD voice using VoLTE). More often than not, operators use a Diameter Routing Agent (DRA) to support correct routing and control of the Diameter signaling related to VoLTE.
Basic session binding
In 3GPP, a DRA is defined for session binding in IP-CAN sessions (equivalent to PDP context in 3G) towards a PCRF server. This was designed for multiple Diameter sessions in VoLTE in order to control the LTE and the IMS parts of the VoLTE service. To maintain an efficient and scalable network rollout, it is important that the LTE parts of an IMS VoLTE call, together with the IMS parts, are controlled by one and the same PCRF (server). Similarly, consistent policy rules need to be applied to the session that are related to the same VoLTE call. Let’s explore in some more detail what needs to be managed by the same PCRF server and why.
When using a VoLTE-enabled device, the mobile subscriber first needs to register to the network and establish the default data bearer to exchange data with the network or applications. This is followed by the authentication and authorization procedures, and mobility management communication between an MME and the HSS where the subscriber profile is stored. (Incidentally, the signaling for these procedures typically uses the Diameter S6a interface that is also often routed with help of a DRA).
Now this device can establish the always-on LTE default user data bearer. In order to do so the device communicates with the PGW and establishes a user data session. For that user data session, in this case still the default bearer, the PGW needs to contact the PCRF via the Diameter Gx interface and receive the policy and charging rules for this customer’s data session.
Once the policies have been exchanged and applied by the PGW and sometimes there are other involved PCEFs (Policy and Charging Enforcement Function), the mobile user can either use Internet services via the established default bearer or in our scenario, opts to continue to establish a VoLTE call.
To do so the VoLTE application on the handset will communicate (via SIP, over the established default LTE bearer) with the IMS network and its embedded VoLTE application server. First a SIP signaling bearer needs to be established after policy for that bearer is applied. To apply the policy, the IMS’s P-CSCF needs to communicate via the Diameter Rx interface with a PCRF server. Actually, it needs to communicate with the same PCRF server that was already involved in managing the related LTE default bearer.
This is exactly where the added-value of a DRA’s session binding functionality becomes necessary, because the DRA has to search its memory for the same PCRF server that was used in the Gx session for that specific customer (e.g. specific IMSI and session ID). It has to match the unique and related information in the Rx signaling in order to make the same routing decision and end up at the same PCRF server.
The relevant IMS information is the Framed-IP address because IMSIs are not usually required in IMS. A smart DRA has stored in its memory the association between an IMSI and Session-ID plus the Framed-IP address used by the device. If now that same Framed-IP address shows up in an IMS Diameter Rx message, a match can be made and the same routing decision can be applied.
Now once the Diameter Gx for the LTE part and the Diameter Rx for the IMS part are bound to the same PCRF server we are almost there. Next comes the exchange and application of the policy and charging rules for the SIP Signaling bearer.
And now we can move to the third key component of the VoLTE call and that is the SIP signaled voice. For voice signaling, the same PCRF server needs to be addressed, and the related IMS signaling is again exchanged via the Diameter Rx interface. Finally, once the policies and charging have been exchanged and applied, the VoLTE call can be made successfully.
If there is a need for changing the policy or charging rules (for instance, if a customer reaches a certain threshold), than the same PCRF server can communicate via Gx to the LTE’s PCEFs and via Rx to the involved IMS elements like the P-CSCF. In this way, the various sessions that are related to the same VoLTE service are managed consistently. Also when the VoLTE call is terminated the various sessions need to be released, except for the LTE default bearer, and the correlation between the LTE and IMS part of this VoLTE call can be cancelled.
Other DRA added-value in VoLTE
There’s additional value to the fundamental session binding functionality of a DRA. A DRA can enable optimal call management ensuring higher quality-of-service VoLTE calls. For instance, think of all the different vendors’ equipment that is needed to exchange Diameter Gx and Rx signaling. One example is when the LTE PGW has a different Gx implementation than the PCRF. In turn that PCRF can have a different Diameter Rx implementation than the IMS’s P-CSCF node. Typically inside an operator’s network, there will be various vendors for LTE, PCRF and IMS core network elements. And this is the norm in roaming use cases where the visited LTE network is out of control (meaning a different vendor) than the home IMS network, where the P-CSCF (and other elements) will be involved.
In addition, once VoLTE takes off more substantially, the quantity of signaling also will take off and increase dramatically. Therefore, a DRA will play the most significant role in providing load balancing and overload control, both in normal circumstance but clearly also under special circumstances like when network elements went down and recover or other heavy signaling loads are occurring.
A DRA could also prioritize VoLTE related signaling, over all the various Diameter interfaces. When serving this function, operators can provide a higher quality VoLTE service over other services, particularly when other services load the network. In this case, a network without this DRA functionality of prioritization, would experience degraded VoLTE service.
There are more added-value functionalities – all made possible by a DRA, like VoLTE specific KPI generation. As time goes on and we experience increased use of VoLTE, we will learn more and more about how a DRA can improve the quality and efficiency of VoLTE and its related services.
Peter Nas serves as Senior Solution Architect for the Traffix SDC team at F5 Networks and draws from more than 20 years of telecom experience to advise operators how to leverage Diameter signaling solutions to enable the optimal LTE experience. Peter joined F5 with the company’s acquisition of Traffix where he was responsible for global business development.  Prior to joining Traffix, he worked at Tekelec focusing on market development for Diameter and SIP routing. In his days before Tekelec, he served as Core Network Engineering Manager at a prominent mobile operator in the Netherlands.
Thanks for the interesting article. I was interested in this: “A DRA could also prioritize VoLTE related signaling, over all the various Diameter interfaces. When serving this function, operators can provide a higher quality VoLTE service over other services, particularly when other services load the network.” Can I detect whether my Operator has activated such a feature through traces that I can see in Wireshark for instance?
Hello fnm500, thanks for your question. At this moment in time it is very early days of VoLTE signaling and operators deploying VoLTE have not seen capacity issues yet to make them prioritize VoLTE signaling. But once that will be done there could be various ways to do it (like on IMSI, on specific AVP content, prioritizing SIP signaling bearer, etc.). My expectation is that in general it won’t be visible in Wireshark other then comparing timestamps (but guess that is more theoritical then practical). The priority/routing decisions will be made by the DRA (so inside) and no visible marks to the diameter signaling. Hope this helps?!
