Why do we add “%” when we create node. Please see the below. Thank you
create ltm node NODE_10 { address 10.1.1.1%2 }
You don’t have to if you don’t want to.
The % is used for route domain formatting where you may have the same IP defined in two separate locations. The % allows you to then segregate that IP to a route domain ID.
Here’s some background info: 404 Page not found | BIG-IP Documentation
